write transient data of plane
Old   June 24, 2005, 05:37
Default write transient data of plane
Fabian
I would like to write out data from a LES, but just a certain plane for a special variable. Somehow I am just able to select boundaries or the whole domain.
Does anybody can give me a hint, how to do this?
Best Greetings! Fabian
Old   June 26, 2005, 18:56
Default Re: write transient data of plane
You can do this easily in CFX-Post. If you are trying to do this in the solver then you will need to put some boundary condition there. If you split the mesh and insert a 1 to 1 domain interface that should do the trick.
At this stage there is no way of doing what you request in the solver at arbitrary planes.
Old   June 27, 2005, 02:38
Fabian
Hi Glenn,
thanks. Doing it in post would take to much space, so the interface is my option. Do you know if this has any effect to the calculation?
Greetings! Fabian
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
graph transient post data at sensor point Micha Siemens 6 March 20, 2013 04:17
validation data for high pressure transient gas injection doki FLUENT 0 September 26, 2010 10:48
[OpenFOAM] How to create an contour plot for arbitrary plane with interpolated data navaladi ParaView 0 June 4, 2008 07:57
how to calculate scalar data at a particular plane premchand Siemens 4 May 27, 2008 10:32
