-   -   Surface in CFX-Mesh (http://www.cfd-online.com/Forums/cfx/21278-surface-cfx-mesh.html)
TM May 23, 2005 01:23
Surface in CFX-Mesh
Is there anyway to mesh a surface object (not a solid) in a volume within CFX-Mesh?
Glenn Horrocks May 24, 2005 18:38
Re: Surface in CFX-Mesh
What are you trying to do?
TM May 24, 2005 19:46
We are trying to simulate a spinnaker as a surface so that it has no thickness. In the past we have used Fluent/Gambit for the simulation and now we are trying to setup the same parameter in CFX. Unfortunately the only meshing software we currently have access to is CFX-Mesh.
Glenn Horrocks May 25, 2005 18:43
Yes, you can do that. There are a number of ways to do it. I think a tutorial example shows how to make a thin surface in CFX-Mesh. An alternative method is to make two seperate solids, joined through the spinnaker. In CFX-Pre you define the surfaces as walls.
regards, Glenn Horrocks
