Home > Forums > CFX
CFX5-POST
Old   June 2, 2005, 00:25
Default CFX5-POST
KKA
Hi guys
My CFX5 post does not export enough data points any time I export file. Do any one has an idea why? Please don't tell me that I used "cut" and not "sample". Because I've done that and it does work. Even the "cut" export less points than "sample" if large sample number is specified. At a location, even if I specified 1000 sample points, it'll only export 8 points. I seriously need help on this , if any one has solution please drop me lines!!
Old   June 2, 2005, 12:38
Default Re: CFX5-POST
Rui
Which version of CFX are you using? CFX-5.7?If so, in which format are you exporting the data? .csv, .dat or .txt?
But you may try this: In the <big>Formatting</big> tab, check the <big>Include Nodes With Undefined Variable</big> box and chose the option <big>null</big>. Export the data and see if there are points with the "value" <big>null</big>.
Regards,
Rui
Old   June 2, 2005, 23:36
Robin
Did you select your plane in the export dialog?
Old   June 5, 2005, 22:00
Roy
I also has this problem when I export the data. I create a line on the boundary and wish to extract 1000 samples along the line but Post only give me 20 data when I use the export function.
Is that sth related to my mesh density? Will the length of the line matter in this case?
Anyone that know the answer please kindly clarify for me..... Thanks.
Thread Tools
Trackbacks are On
NO model vs post processing in coal combustion,CFX sakalido CFX 1 April 15, 2011 14:07
Linking between my own code and CFX5 in Windows Se-Hee CFX 2 May 17, 2007 08:52
Error message from the CFX5 Post Sinjae CFX 2 December 9, 2005 17:08
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
mpeg in CFX5 POST henry CFX 7 November 23, 2002 15:50
