Home > Forums > CFX
HELP:motor admission problem
Old   June 2, 2005, 09:07
Default HELP:motor admission problem
Brian
Hi i would like to simulate the admission in a cylinder and the compression of gazes using mesh deformation. the piston and the valve move very well but i can't close totally the valve because of conservation of topology (i can't use different meshes because i don't have the Compaq compiler CVF). i need help to totally close the valve in order to simulate the compression. thanks
Old   June 2, 2005, 20:04
Default Re: HELP:motor admission problem
You have two main options with CFX: 1) The next version of CFX will have some tolerance of zero volume elements. You may be able to fully close the valves when it comes out. I have done a quick trial of it on the beta version and it did not work for me, but maybe with a bit of planning you might get it to work.
2) Use a GGI interface and slide it shut.
Regards, Glenn
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
