Does CFX uses SSE2?
Old   June 3, 2005, 10:22
Default Does CFX uses SSE2?
Korsh Mik
Dear Sirs,
I've seen "intel_p4.sse2_winnt5.1" in out file on one P4 computer and "intel_pentium_winnt5.1" on another one.
Does these architecture signatures mean that on the first computer SSE2 is used, while in second one - not used?
Why it could be possible? CPU are P4 2.4GHz on the 1st comp, and P4 3.0GHz on the 2nd.
Thnk you!
Old   June 3, 2005, 10:39
Default Re: Does CFX uses SSE2?
Rui
I just can tell you that, in my PC, the .out file created by CFX-5.6 contains "intel_p4_winnt5.0", while the .out file created by CFX-5.7.1 contains "intel_p4.sse2_winnt5.0".
But I don't know the reason, and I even don't know what SSE2 means.
Regards,
Rui
Old   June 5, 2005, 19:29
Neale
CFX attempts to detect your hardware to aid in selecting a correct solver executable. That is why it prints the that string to the output file.
CFX however, does not use SSE. So, don't worry about it.
SSE stands for "Streaming SIMD Execution" I think. It's a special execution mode for floating point calculations which Intel implemented into the pentium 3 and later CPUs.
Neale
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
