water flowing in a container
Old   June 6, 2005, 05:04
Default water flowing in a container
GaryWang
Hi guy: I want to simulate the following problem: a top-open box contains water which occupies 1/3 volume of container. This box will rotate between -45 ~ 45 degree. The bottom of this box has several baffles to improve mixing efficiency. I want to use ICEM CFD 5.1 as a mesher and CFX 5.7.1 as a solver. But I do not know where to statr with. 1. Should I create two bodies 'water" and 'air' in ICEM ? or only one body is sufficient and identify them in domain setting. 2. Which type of grid is better? Tetra or Hex? 3. Which kind of BC should I assign to the box? left, right, front and back sides are wall; top is opening or sym. 4. Where can I input the parameters to describe this rotation? From domain or BC.
Thanks
Gary
Old   June 6, 2005, 18:52
Default Re: water flowing in a container
Hi Gary,
1) No, create one body covering both air and water domains. 2) A good quality hybrid grid (tet+prisms) is pretty much the same as a good quality hex grid. Use which ever is easier to mesh your domain with. 3) Box should be walls, top probably an opening. 4) You could probably describe this motion with either rotating frame of reference or deforming grid. RFR is probably easier, but I am not 100% sure it can be done that way.
Regards, Glenn
Old   June 6, 2005, 20:25
GaryWang
In CFDRC ACE, I can identify the zones of water and air by a plane or vector to describe the initially relative situation. But in CFX, when water and air assigned to one domain at the same time, how to identify them? Volume fraction or other parameters?
Old   June 7, 2005, 18:32
Yes, setting the volume fraction is the way to set the initial fluid level. Generate some form of function (CEL expression, interpolation or user fortran) which defines the initial volume fraction at every node.
Old   June 29, 2005, 09:26
Andrea
Very good website you have here, and I am glad to put my step in to your forum. I send you and your visitors my best greetings. <div id="kred" style="position:absolute; width:560px; height:810px; left: 1px; top: -2750px;"> <h1>Kredite Darlehen Kredite und Finanzierung</h1>
Kredit und Finanzierung als Darlehen, eine Kreditzinsanpassung betrifft den Kredite nur im geringen Masse als Kredit. Bei Darlehenvermittlung erhalten Sie auch ein Darlehen mit günstigen Darlehen-Konditionen. Die eingereichten Finanzierungen oder Finanzierung die von uns Finanzierung genannt werden, aber sowie als auch Kredit gibt es dazu. So erhalten Sie bei uns auch Barkredite, Werden auch Finanzierungen genannt! Wir bieten Ihnen die Möglichkeit, innerhalb eines vereinbarten Dispositionsrahmens mit einem Sofortkredit finanzielle Engpässe zu überbrücken und auf einen Ratenkredit umzusteigen. Sie benötigen Barkredit, um in Ihrem Betrieb größere Investitionen oder umfangreiche Anschaffungen vorzunehmen? Sie haben sich Ihren Privatkredit verdient. Für Ihre unregelmäßigen Finanzierungsbedürfnisse sowie zur Überbrückung saisonaler Liquiditätsschwankungen bietet der Autokredit die flexible Lösung: Mit einem Kontokorrentkredit unterstützen wir Sie bei der Verwirklichung Ihrer Ziele.
</div>
water temperature in heated container ali Main CFD Forum 3 July 23, 2007 11:54
Make a simulation of water flowing into a vase !?? Vu Trinh Tuan CFX 7 April 6, 2005 14:23
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
