Surface reaction for methane combustion
Old   May 14, 2019, 06:37
Default Surface reaction for methane combustion
Abdullah Arslan
Goenitz is on a distinguished road
I am modelling a simple combustion problem using Arrhenius equation. I set the activation temperature to be 3000K and all other wall/inlet/opening temperature to be 273 K. The point is reaction is still taking place in bulk gas.
Moreover i need reaction on just catalyst surface (for now either a high temperature or heat flux in). How can I achieve that?
I have defined material in CFX using Reacting mixture>Gas Phase Combustion>Reaction(defined in Arrhenius tab).
any help?
Goenitz is offline   Reply With Quote
Old   May 14, 2019, 07:32
Please start a new thread for a new question. Do not hijack other threads. I have moved this question to a new thread.
Have you looked to see if there are combustion and chemistry examples on the ANSYS Customer webpage? If there is nothing suitable there you should contact ANSYS support as they have access to lots more examples. The best way to get started into a new type of simulation is from a tutorial example.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   May 14, 2019, 08:31
Abdullah Arslan
Thank you for reply.
i thought it is against forum rules to open new thread when already same/similar question has been asked.
yes, I have done plenty of tutorials from youtube, ANSYS student portal, and others like from eureka.im.
Actually, those are ok but when i model my own reaction then problem starts.
Error in New Surface reaction model (Having multiple reactions) surajkvs OpenFOAM Programming & Development 2 May 23, 2023 21:21
Having problem importing surface reaction mechanism from CHEMKIN Quntin FLUENT 0 March 10, 2016 01:25
particle surface reaction unnikrishnan FLUENT 0 January 26, 2016 00:12
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
surface reaction UDF taekyu8 Fluent UDF and Scheme Programming 1 June 16, 2013 03:23
