Mesh Size
Old   June 15, 2005, 10:11
Default Mesh Size
Meri
I have a mesh that I generated with a code in ICEM-CFD format. However, when I attempted to load into Pre, it took a long time, and finally I got an error message about it been to big its about 368MB in size, is there a limit then to what you can bring in ? or is there a switch of some kind. I will appreciate if any one knows or had similar experience.
Old   June 15, 2005, 18:43
Default Re: Mesh Size
There is a technical note on the CFX-Community website about maximum model size for the different parts of CFX.
Old   June 16, 2005, 01:04
Meri
would you know how toget to it ?
Old   June 16, 2005, 02:49
Aziz
Hi Glenn, I am interested in knowing the maximum Mesh size what CFX can solve. I have checked into CFX Community Forum and search for Mesh size but couldnt find the information can you please tell me exactly what exactly the forum question is?
Best Wishes
Aziz
Old   June 16, 2005, 05:30
Rui
I think Glenn refers to this technical tip: Memory Limitations When Running CFX-5, http://www-waterloo.ansys.com/cfxcom...oblem_size.htm
Rui
Old   June 16, 2005, 06:36
Meri
Rui, My question has to do with when loading the files into Pre.
Old   June 16, 2005, 08:20
Gang
Last part of that article talks about the maximum problem size that can be set up in Pre. By the way, what's the number of nodes or elements of your mesh? And what's the machine and OS you use to run Pre?
Old   June 16, 2005, 14:04
Meri
I can not determine the number of nodes because it does not get loaded to Pre. I am using Linux Redhat 7.3 with 2Gb of memory.
Old   June 16, 2005, 18:17
Does your meshing software tell you how many nodes?
Old   June 17, 2005, 04:27
TB
You can load it to ICEMCFD and see if it will work. If it works okay, then output the mesh file from ICEM directly. ICEM should be able to tell you the no. of nodes in your domain.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
Gambit Unstructed (Tet) Mesh - size control newbie FLUENT 3 August 26, 2008 11:38
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
How to decide the mesh size? echo Siemens 1 May 23, 2006 05:34
