Simple Programming
Old   June 10, 2005, 19:24
Default Simple Programming
RK
I need to calculate two things: (C5=SCAL1, C6=SCAL2)
(1) pH=-log10(R*C5)
(2) R=f(pH,C6)
As written below the value of R is only known at the first node, but some value at others; using this approach the calculations are WRONG! Can someone offer a solution as to how one can wirte this simple code? (Since R is a variable, specifying within the loop as a constant defeats the purpose of the calculation)!
Hope someone can help (and thanks for your help).
SUBROUTINE USRINT
CALL IPALL(BLAH...)
pH=value1 R=value2
DO 101 I=1,NPT
INODE=IPT(I)
C5=MAX(SCAL(INODE,IPHASE,ISC1),SMALL)
C7=MAX(SCAL(INODE,IPHASE,ISC2),SMALL)
r=MAX(USRGR(INODE,IPHASE),SMALL)
C5= VALUE3
C6= VALUE4
C7= VALUE5
pH= -LOG10(r*C5)
C10= pH
r= f(pH,C5,C7)
100 CONTINUE
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
How to add correcting pressure equation in SIMPLE of MRFSimpleFOAM? renyun0511 OpenFOAM Programming & Development 0 November 4, 2010 01:38
compressible SIMPLE method fakor Main CFD Forum 1 August 30, 2010 11:21
PISO vs. SIMPLE benedikt flurl Main CFD Forum 2 April 14, 2005 06:54
flow over a 2D cyl using SIMPLE T Main CFD Forum 1 January 27, 2001 07:32
