June 16, 2005, 07:36 |
Negative quality elements in ICEM Grid
Hi
I use ICEM CFD to mesh a cascade. i get negative quality in quality check only on the suction side of airfoil. And at a particular point, the grid is clustered though i have not clustered the grid. Also at some spots meshes overlap. Kindly suggest me some remidy and the probable reason Thanks Kartik |
June 16, 2005, 09:00 |
Re: Negative quality elements in ICEM Grid
I would check edge projections/associations first. You can also view the edges with the projected shape (Edges options Nodes)
June 17, 2005, 04:45 |
What mesh are you using? Try hexa. If you're using tetra, then try CFX-Mesh.
ICEM CFD - preset quality criteria | JSM | CFX | 2 | May 7, 2008 23:36 |
Exporting ICEM Tetra Grid to Fluent with Hexa-Core | Tim | FLUENT | 2 | August 30, 2007 07:16 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
Grid Quality and the Solution | Faraz | Main CFD Forum | 4 | January 10, 2000 18:18 |
