SU & SP: CFX 4.4 HELP!!!
I want to put source: Source=R3-R2-R1 where R1, R2 and R3 represent different expressions. R1=+ive, R2=-ive, R3=+ive At the moment, I am carrying out the following operation: SP(INODE,IPHASE)=SP(INODE,IPHASE)+R2*VOL(INODE) SU(INODE,IPHASE)=SU(INODE,IPHASE)+((R3-R1))*VOL(INODE). This is causing a divergence. Does anyone have any other way of doing it!...I hope so...? Thanks in Advance, Robin K |
Re: SU & SP: CFX 4.4 HELP!!!
Robin,
The form of a source term, when solving for variable phi is as follows: Source = SU + SP * phi Since in your source term, you don't have any variables that are a function of the solved variable, phi, SP should be zero. SU(INODE,IPHASE) = SU(INODE,IPHASE) + R3 - R2 - R1 SP(INODE,IPHASE) = SP(INODE,IPHASE) + 0.0 Use this if your source is mostly positive. If (R3-R2-R1) is very negative, you may want to put this in the SP term by first dividing by phi (since the code will multiply it by phi later). This would be: SU(INODE,IPHASE) = SU(INODE,IPHASE) + 0.0 SP(INODE,IPHASE) = SP(INODE,IPHASE) + (R3-R2-R1)/phi(INODE,IPHASE) This will make the matrix more diagonally dominant when SP gets carried to the other side and incorporated into the matrix diagonal. Jeff |
