-   -   Automatic post processing of Transient simulation (http://www.cfd-online.com/Forums/cfx/21370-automatic-post-processing-transient-simulation.html)
Aziz June 24, 2005 04:47
Hello
I have been trying to do some post processing calculation for my transient simulation. I have done this per hand very often but now i want it to be automatic so that i can use it for optimization process.
My query is:
I want to calculate the total energy at the inlet and outlet of the nozzle which is time dependent. I used to write density, pressure and velocity at the inlet and outlet by exporting the values from chart in CFX-Post and than in Excel i did further calculation to find the nozzle efficiency in transient flow.
Any one know how can you use command editor in CFX-Post to store and calculate the sum of energy over time.
Just for reference the equations are like that:
Efficiency = Numerator / Denomenator
Numerator = Sum((Pressure * Velocity * Area)@outlet*DeltaT)+Sum((0.5*density*Area*Velocit y^3)@outlet
Denomerator = should be same as Numerator but calcualted for inlet
thanks
Aziz
Rui June 24, 2005 12:34
Re: Automatic post processing of Transient simulat
Can't you do that with CEL expressions?
What does Sum mean? Summation over the area, or over the time?What does DeltaT mean? Does T stand dor time or for temperature?
Rui
TB June 24, 2005 14:37
Refer to CEL user manual and then use PERL language for the programming syntax under command editor. It's pretty simple (I only spend one week to learn PERL and I can automate basically anything in Post now). There're quite some free references about PERL programming on Google.
Cheers.
