Home > Forums > CFX
Roughness for K-Omega Turbulence models
Old   July 1, 2005, 05:30
Default Roughness for K-Omega Turbulence models
ratnam
We want to use K-omega based turbulence model for flow over terrain by using Roughness and checked the previous messages in forum. But we are not able to edit in CCL as mentioned in previous messages in forum with an error message "it is not physically valid". Please Can any body suggest if we went wrong, r else is there any other way to input roughness for K-omega based models in CFX.
Thanks, Ratnam.
Old   July 1, 2005, 20:52
Default Re: Roughness for K-Omega Turbulence models
Jeff
I've set surface roughness with no problem in CCL for the SST (K-omega based) model. This only works in 5.7.1 (I believe).
Also, look at the CCL for roughness on a k-epsilon case to make sure you have the syntax correct. The options are case sensitive.
Jeff
Thread Tools
Trackbacks are On
About BC for turbulence k-omega models. Stokes Main CFD Forum 1 May 7, 2013 16:42
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Are there more FLUENT Turbulence Models? Travis FLUENT 3 December 30, 2008 02:45
wall roughness with SST turbulence model in CFX10 Vincent CFX 7 September 10, 2007 16:49
Turbulence models for GCV method dosen't work! Sima Baheri Phoenics 0 January 6, 2007 05:08
