-   -   about Y+ in SST model (http://www.cfd-online.com/Forums/cfx/21428-about-y-sst-model.html)
zuozicheng July 11, 2005 07:29
hi all
when i make grids in my airplane in order to compute results at Ma=0.2, alpha=8, i use SST model, auto wallfuntion , i posted a computed result and see Y+=30-300,
but the help files say if low Re model(such as SST),Y+=2.0 , in boudarylayers, there must be 10 points, or SST model can also accept wall Function, so i want to know how i set Y+ in SST? would you tell me the true way if you have some idea?
WT July 12, 2005 08:47
Re: about Y+ in SST model
Hi Zuozicheng,
as I understand the manual, the SST model automatically adapts itself whether or not it is using wallfunctions depending on the local Y+, i.e. the grid resolution. So, if you think a small Y+ is beneficial for your simulation, create a grid with a fine boundary layer resolution and CFX will use the SST model without wallfunctions. Otherwise, if the grid is coarser in the boundary layer, wall functions will be applied.
Hth,
-Thomas
zuozicheng July 12, 2005 10:05
лл
