July 11, 2005, 07:29 |
about Y+ in SST model
hi all
when i make grids in my airplane in order to compute results at Ma=0.2, alpha=8, i use SST model, auto wallfuntion , i posted a computed result and see Y+=30-300, but the help files say if low Re model(such as SST),Y+=2.0 , in boudarylayers, there must be 10 points, or SST model can also accept wall Function, so i want to know how i set Y+ in SST? would you tell me the true way if you have some idea? |
July 12, 2005, 08:47 |
Re: about Y+ in SST model
Hi Zuozicheng,
as I understand the manual, the SST model automatically adapts itself whether or not it is using wallfunctions depending on the local Y+, i.e. the grid resolution. So, if you think a small Y+ is beneficial for your simulation, create a grid with a fine boundary layer resolution and CFX will use the SST model without wallfunctions. Otherwise, if the grid is coarser in the boundary layer, wall functions will be applied. Hth, -Thomas |
July 12, 2005, 10:05 |
лл
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
why SST model??? | vijay | CFX | 3 | May 22, 2008 03:05 |
Convergence issue in SST for Porous model | Raj | CFX | 0 | May 2, 2008 02:43 |
SST model and boundary layers | Rodrigo Basniak | CFX | 7 | March 27, 2008 14:19 |
Stalling residuals in kw SST turbulence model | jorllam | CFX | 3 | February 13, 2007 15:51 |
