about Y+ in SST model
Old   July 11, 2005, 07:29
Default about Y+ in SST model
zuozicheng
hi all
when i make grids in my airplane in order to compute results at Ma=0.2, alpha=8, i use SST model, auto wallfuntion , i posted a computed result and see Y+=30-300,
but the help files say if low Re model(such as SST),Y+=2.0 , in boudarylayers, there must be 10 points, or SST model can also accept wall Function, so i want to know how i set Y+ in SST? would you tell me the true way if you have some idea?
Old   July 12, 2005, 08:47
Default Re: about Y+ in SST model
WT
Hi Zuozicheng,
as I understand the manual, the SST model automatically adapts itself whether or not it is using wallfunctions depending on the local Y+, i.e. the grid resolution. So, if you think a small Y+ is beneficial for your simulation, create a grid with a fine boundary layer resolution and CFX will use the SST model without wallfunctions. Otherwise, if the grid is coarser in the boundary layer, wall functions will be applied.
Hth,
-Thomas
Old   July 12, 2005, 10:05
zuozicheng
лл
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
why SST model??? vijay CFX 3 May 22, 2008 03:05
Convergence issue in SST for Porous model Raj CFX 0 May 2, 2008 02:43
SST model and boundary layers Rodrigo Basniak CFX 7 March 27, 2008 14:19
Stalling residuals in kw SST turbulence model jorllam CFX 3 February 13, 2007 15:51
