July 16, 2005, 09:15 |
Urgent - Patran vloume meshing
Hi friends,
I am trying to use Patran vloume meshing method for a RECTANGULAR BOX with inlet and outlet connected to some faces of box. I am not able to generate the Patran vol mesh because the SURFACES WITH INLET AND OUTLET are TREAMED SURFACES hence are NOT BIPARAMETRIC. To be more clear imagine a BOX(TANK) with 6 faces and two of these faces are having pipes(circ/rect c/s) connected. One pipe as inlet and other as outlet. Since these faces of box are NOT having <= 4 edges and are trimed surfaces i can not use Patran meshing... Can somebody tell me the solution for this? Has somebody done this case in patran meshing mode? Thank you in advance Tuks |
problem in meshing - urgent ! help please | khairul hadi | FLUENT | 3 | August 21, 2008 11:42 |
Patran Volume Meshing | Ting | CFX | 1 | March 19, 2004 17:33 |
Patran Volume Meshing | Deb | CFX | 19 | April 17, 2003 10:56 |
Patran Volume Meshing | Jackie | CFX | 5 | March 27, 2003 03:08 |
urgent help needed for meshing in GAMBIT | chris | FLUENT | 0 | September 5, 2002 09:18 |
