Urgent - Patran vloume meshing
Old   July 16, 2005, 09:15
Default Urgent - Patran vloume meshing
Tuks
Hi friends,
I am trying to use Patran vloume meshing method for a RECTANGULAR BOX with inlet and outlet connected to some faces of box. I am not able to generate the Patran vol mesh because the SURFACES WITH INLET AND OUTLET are TREAMED SURFACES hence are NOT BIPARAMETRIC. To be more clear imagine a BOX(TANK) with 6 faces and two of these faces are having pipes(circ/rect c/s) connected. One pipe as inlet and other as outlet. Since these faces of box are NOT having <= 4 edges and are trimed surfaces i can not use Patran meshing...
Can somebody tell me the solution for this? Has somebody done this case in patran meshing mode?
Thank you in advance Tuks
problem in meshing - urgent ! help please khairul hadi FLUENT 3 August 21, 2008 11:42
Patran Volume Meshing Ting CFX 1 March 19, 2004 17:33
Patran Volume Meshing Deb CFX 19 April 17, 2003 10:56
Patran Volume Meshing Jackie CFX 5 March 27, 2003 03:08
urgent help needed for meshing in GAMBIT chris FLUENT 0 September 5, 2002 09:18
