GETTING THE NODES NUMBER FOR A SPECIFIC SURFACE
Old   July 20, 2005, 05:11
Default GETTING THE NODES NUMBER FOR A SPECIFIC SURFACE
CHGL
Hi all,
I have run a steady state thermal problem of a rotating disc with straigth channels. I have exported the data for the WALL HEAT TRANSFER COEFFICIENT and the WALL ADJACENT TEMPERATURE (csv file), these data preceded by the node numbers.
I want to know how I can select from these data, the corresponding data (say node numbers) for a specific set of surfaces: the 4 walls of the channels and their inlet/outlet surfaces. I need to know this in order to perform further calculations with these numbers.
Any idea is welcomed.
Regards
CHGL
Old   July 20, 2005, 06:28
Default DO NOT ANSWER PLEASE... I FOUND IT
Carl
THKS.
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Nusselt number variation over a ribbed surface avi031 FLUENT 2 March 10, 2011 12:09
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
