July 26, 2005, 09:32 |
Turbulence Models
I need some help or explanations to resolve some issues regarding turblulent modeling in CFX, I am studying an external flow problem and comparing with wind tunnel test. I have tried different schemes in the program : The SST-with high resolution is pretty correct predicting the Lift. K-epsilon with Upwind provides (although still off)the closest to the Drag and The SST with specified blend is in between. I will like to know if anyone knows how the Torque is being calculated in the program, secondly I wonder if the High resolution can be improved. Perhaps some one has some experience with this. Thanks.
July 26, 2005, 18:31 |
Re: Turbulence Models
You might get better accuracy using the specified blend factor spacial differencing rather than high resolution. Use a blend factor of 1.0 to use purely second order differencing. This may give an increase in accuracy over high-resolution differencing. The torque reported in the output file is around the default coordinate system, that is the point 0,0,0 in your mesh model. Regards, Glenn Horrocks |
July 27, 2005, 01:49 |
Thanks Glenn, Suppose I desire the Torque about a different location, like the centroid of my object in the domain ? I am gradually adjusting the blend factor to see its influence.
July 27, 2005, 03:40 |
In CFX-Post you can use the Function Calculator to evaluate the torque on any locator about any global axis, and also about any user Coord Frame axis created in CFX-Post. Regards, Johnson |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Incompressible Turbulence models | achinta | OpenFOAM | 4 | May 27, 2010 10:35 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
How to set phase dependent turbulence models? | J.Yang | CFX | 2 | August 29, 2002 15:39 |
