Home > Forums > CFX
Will ICEMCFD mesh multibody/multisolid geometry?
Old   August 3, 2005, 10:13
Default Will ICEMCFD mesh multibody/multisolid geometry?
CFX5.7User
Currently I am using CFX-Mesh to mesh a multisolid part(generated from other 3D pakages, I combine these solids into one part in Workbench), then in CFX-Pre I can choose one of the solids as subdomain. I would say this is one of best features in CFX-Mesh.
I want to know if I can do the same thing in ICEM CFD, if I can, could you please tell me how?
Thanks.
Old   August 3, 2005, 18:18
Default Re: Will ICEMCFD mesh multibody/multisolid geometr
ICEM is the advanced meshing option in CFX these days and can mesh just about anything, but it is a little harder to use and requires a little more training. Therefore you almost certainly can mesh your geometry in ICEM, but I recommend you do some tutorial examples and/or training before you do so, to give you a background in the software.
Regards, Glenn Horrocks
Old   August 4, 2005, 10:24
Myron
For meshing with Tets - by default it will mesh each volume bounded by surfaces as a separate Part (grouping of mesh elements). These will then show as subdomains in CFX-Pre. Or - you can define Material Points/Bodies within the regions you want to mesh.
Old   August 4, 2005, 10:56
CFX5.7User
Thanks. Glenn and Myron. I will try that.
Old   August 4, 2005, 14:26
CFX5.7User
I tried one cube in cube case, the subdomain (inside cube) works fine in CFX-Pre with ICEM CFD mesh. However, it seems every BC used in CFX-Pre has to be defined in ICEM CFD mesh, otherwise, that face can not be selectable, which is not like CFX-Mesh, face can be selected as BC in CFX-Pre.
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 24 June 27, 2016 08:54
[ICEM] Create geometry (iges or step file) from fluent mesh muketa ANSYS Meshing & Geometry 10 August 5, 2015 05:38
Gambit problems Althea FLUENT 21 February 6, 2001 08:05
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
