Home > Forums > CFX
solver error message
Old   August 10, 2005, 00:09
Default solver error message
Rashmi
dear all, i m doing a simple crankshaft simulation using CFX and the BC's are static pressure at inlet-576 [pa] and static pressure at outlet- 0 [pa].
it has one inlet and four outlets. this is actually an oil flow simulation thru the crankshaft of a rotary compressor
and when i m giving it a "run" in the solver...i m getting an error message as "fatal overflow error in a linear solver"....what is this mean ?
i want to know the answer !!!
could anyone plz help me out in this issue
regards with thnx Rashmi V Rao
Old   August 10, 2005, 02:27
Default Re: solver error message
Santhosh
As you can see from most previous posts on this topic, it can be due to a variety of reasons like mesh, BCs, timestep etc. In your case most probably due to the BCs, this is well documented in the help files. Try a differnt BC at inlet say massflow.
Santhosh
Old   August 10, 2005, 03:40
test
Well your problem is diverging and has crashed. This is what the error means. If this error is encountered within first few iteration from the start of the simulation, there is a definite issue with the bc/physics setup/timestep in the case.
You have used static pressure at the inlet which is a unstable bc. Also the combination of pressure boundary at inlet and outlet makes the case very sensitive to intial guess.
I would suggest you first try giving mass flow at either inlet or outlet. Make sure you change the static pressure condition at the inlet to total pressure atleast.
Regards, test
Old   August 10, 2005, 04:38
Rashmi
dear all
thnx a lot for ur valuable suggestion !!!!!!!!! i will surely try out what all u told me to do.
thnx once again
regards Rashmi V Rao
Old   August 10, 2005, 06:17
Rashmi
DEAR ALL
AS test SAID I CHANGED THE INLET BC AS MASS FLOW RATE AND KEPT THE OUTLET BC AS STATIC PRESSURE....BUT STILL I M NOT ABLE TO "RUN" THAT SIMULATION IN THE CFX...THE SAME ERROR IS SHOWN.("FATAL OVERFLOW IN LINEAR SOLVER")
COULDNT FIND THE EXACT REASON. I EVEN REFINED THE MESH TOO.PREVIOUSLY IT WAS AROUND 5,00000 AND NOW IT IS AROUND 10,00000...WHAT SHALL I DO NOW...?
ANYBODY TO HELP IN THIS REGARD THNX WELL IN ADVANCE
RASHMI V RAO
Old   August 10, 2005, 18:34
Try:
1) reducing the timesteps size for the first few timesteps/iterations
2) Using a simpler turbulence model (what turbulence model are you using?)
3) Using upwind differencing and first order time differencing (if transient) to get it started, and change over to a more accurate scheme after you have a better general flow field.
Thread Tools
Trackbacks are On
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
A New Solver for Supersonic Combustion nakul OpenFOAM 6 March 30, 2014 03:00
A New Solver for Supersonic Combustion nakul OpenFOAM Announcements from Other Sources 18 February 19, 2013 08:48
Development of a Low mach PISO solver nishant_hull OpenFOAM Programming & Development 0 August 25, 2009 12:48
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
