Tecplot for CFX post processing
Old   August 19, 2005, 08:54
Default Tecplot for CFX post processing
pantangi goud
Dear All,
Please let me know is it possible to use tecplot for post processing CFX5.7.1 results? If yes, how to do that? If it is needed to convert .res r .bak files to ASCI and then back to binary files which can read by TECHPLOT, if so can u suggest any excutables, which have this capabilty. Please provide all needful information to use tecplot for CFX 5.7.1 post processing Thanks for ur time..
Regards Pradeep
Old   August 22, 2005, 03:09
Default Re: Tecplot for CFX post processing
Paul Lewis
Hi Pradeep,
To get your results into Tecplot you need to set the following Environment Variable on your system:
CFX5_EXPORT_CGNS_TECPLOT = 1
Then use the export tool in CFX-Solver to export your results in CGNS format. In Tecplot you will find the CGNS format (CFD General Notation System) under File > Import.
Regards
Paul
Old   August 24, 2005, 16:42
steven
i think old tecplot verions like 9.0 and some 10.0 verions can't successfully open CGNS files exported by cfx5.7 or 5.7.1. You can export data from cfx-post and write a short fortran code to transfer data file to tecplot file by yourself. It is not hard. Check your tecplot help file to know which format you need.
Ansys Post processing ano999 ANSYS 1 May 27, 2011 16:24
NO model vs post processing in coal combustion,CFX sakalido CFX 1 April 15, 2011 14:07
CFX Post vs. Tecplot (xy-graphs) Tobias CFX 8 October 8, 2010 08:24
post processing for KIVA dirga Main CFD Forum 5 April 23, 2009 10:58
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
