A way of creating blocks in ICEM for seal region |
August 22, 2005, 11:24 |
Experts,
I couldnot attach a picture. I'm stuggling to find a good way of generating a good mesh for the knife edge seal region with honey coomb present. I'm using ICEM blocking technique. But I notice, I'm not able to get much control over mesh density and my mesh is becoming large enough. I attach a picture showing you the case. Please let me is there a way by which I can have fine mesh in the tooth gap region and coarse mesh in the pocket region. Honey coomb mesh got finner mesh at the top Thanks in advance Mustafa |
August 23, 2005, 03:37 |
Re: A way of creating blocks in ICEM for seal regi
You have to make some additional splits, maybe auxiliary points and curves, and then carefully associate your block topology model with seal geometry.
There are several meshing laws available in ICEM CFD for controlling mesh density on each edge. Have a look at "Meshing Tutorial". Best regards, hdj |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
A way of creating blocks in ICEM for seal region | Mustafa T | CFX | 0 | August 22, 2005 11:21 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
