Home > Forums > CFX
free surface
Old   August 24, 2005, 11:15
Default free surface
Jennifer Haque
Hi, I am using CFX 5.7. From what I have read in the manual, it seems that the code uses interface capturing oppose to interface tracking. I wondered if anyone knew which interface capturing method it uses. It seems to me it is the scalar equation method. Can anyone confirm this?
Jennifer
Old   August 24, 2005, 11:37
Default Re: free surface
Rui
For multiphase (n phases) flows, CFX uses the continuity equation of n-1 phases plus the total continuity equation.
For free-surface flows, it uses the total continuity equation and the continuity equation of the primary fluid (the liquid). I suppose this last equation is what you call the scalar equation methodTo keep the interface sharp, as you can read on the Documentation (Solver Theory, Multiphase Theory, Free Surface Flow), CFX uses a compressive advection scheme, a compressive transient scheme and a special treatment of the pressure gradient and gravity terms (but I have no idea what is this special treatment)
Regards,
Rui
Old   August 25, 2005, 02:23
test
The free surface model of CFX-5 is NOT an interface tracking method. No efforts are made in order to track or reconstruct the real interface between the 2 phases. The model in CFX-5 is a surface sharpening algorithm, a so-called "compressive scheme". If you consider the upwind method for the treatment of the convective terms in discretisation, you know that upwinding introduces additional numerical diffusivity to the solution process, commonly leading to a smearing of sharp gradients. The free surface model in CFX-5 is a special discretisation method for the convective terms, which is in contrary anti-diffusive, but with preservation of stability of the flow solver. So it acts against the smearing of sharp gradients as much as possible without loosing stability of the solution process. Free surface is detected everywhere where a grid cell is showing a steep gradient between gas volume fraction of 1.0 and liquid volume fraction of 1.0 in neighboring grid cells.
Hope this helps. There are some conference papers which give a fair detail about the modelling approach. Contact your CFX support people to get these.
Regards, test
Thread Tools
Trackbacks are On
Free surface is below than expected..results are not good mechovator CFX 24 April 8, 2011 00:41
Submarine Free Surface samwh CFX 7 August 30, 2009 07:14
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 16:14
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 21:03
