August 30, 2005, 12:58 |
Version from 5.7.1 to 10
Hi, Iīm surprised because the version change from 5.7.1 to 10.0 Is it really, or the other versions appears and I didnīt saw? There is a great difference between them? Thanks, Lucio
August 30, 2005, 14:59 |
Re: Version from 5.7.1 to 10
Hi, CFX changed from version 5.7.1 directly to version 10. Take a look at http://www.ansys.com/products/newfeatures/fluids.asp
P.S. Does somebody know how I can make a link to a web site work as a link? In the older version of this forum you just had to write it in the message and it would automatically appear as a link. |
August 31, 2005, 05:39 |
Seems like I forgot to turn on the auto-hot-link feature when we switched to the new server. I've enabled it again so now you should be able to just type the address here and get it hot-linked automatically.
Here is a test: www.google.com. It should also be okay to type in the full html code like MatejK showed. Here is test if that link to google. |
Display Modes | |
OpenFOAM on cluster: version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found | ovie | OpenFOAM | 10 | April 19, 2021 19:06 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 08:11 |
bubbleFoam validation case | balkrishna | OpenFOAM Running, Solving & CFD | 24 | August 30, 2010 05:37 |
version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found | ovie | Main CFD Forum | 1 | April 19, 2010 15:00 |
[OpenFOAM] Problem with paraFoam on a linux-64 bit | bunni | ParaView | 4 | April 14, 2010 21:55 |
