September 6, 2005, 09:34 |
grids between tip clearance
hi,everyone.
my model is a axial pump,and the tip clearance is very short to the whole radius. and i met a problem for grids. when i make ogrids for blade,i don't know where to put the ogrids vertices between the shroud and blade tip. and some grids are always wrong with small angel ,such as 0-9 degree. how to avoid this situation? thank you very much! |
September 7, 2005, 05:19 |
Re: grids between tip clearance
I dint get your question saying the axial pump having a shroud? In axial flow pumps the impeller blades are with the hub only. What is the clearence between impeller and casing.?
September 7, 2005, 08:11 |
ah~ the pump was cased, and tip clearance is very small.could you tell me how to set the grids? thank you very much!
Display Modes | |
[ICEM] Turbine blade with filleting and tip clearance | Pursuor | ANSYS Meshing & Geometry | 4 | July 7, 2010 13:56 |
Meshing in tip clearance. | me | Siemens | 0 | August 25, 2008 03:20 |
grids in tip clearance | iceraining | Main CFD Forum | 2 | September 12, 2005 00:50 |
Tip Clearance | Liam | CFX | 3 | September 7, 2005 05:30 |
Tip Clearance | Drona | CFX | 0 | October 17, 2002 05:25 |
