Home > Forums > CFX
Convergence
Old   September 7, 2005, 05:17
Default Convergence
adrian
Hi, Can the experts here give me their view on what they consider good convergence for engineering flows. The CFX documentation mentions it to be residual RMS=1 E -4. Is this appropriate? Does this change convergence criterion change from flow to flow? Adrian
Old   September 7, 2005, 09:22
Default Re: Convergence
Taner Baytekin
you can check up the following in help:
:Solver Modelling
:>Advice on Flow Modelling
:>>Monitoring and Obtaining Convergence
:>>>MAX Residual Level
Basically, 1e-4 is said to be "sufficient for most engineering applications", but the convergence criteria depends on the problem geometry and boundary conditions. I would recommend you to make a test on a typical flow problem that you are interested in: just run a few simulations with different residual levels, and check out the dependency of the flow quantity that you are looking for.
Taner Baytekin
Thread Tools
Trackbacks are On
Convergence Centurion2011 FLUENT 29 August 27, 2016 03:19
problem with Min/max rho tH3f0rC3 OpenFOAM 7 February 23, 2013 06:37
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
