September 8, 2005, 16:29 |
Rotating reference frame problems
I'm having problems creating the rotating domain for the model of a turbine. The problem is with zero radius.
Apparently it can't handle a rotating volume that doesn't have a hole in the middle. Is this true? How would you model a rotating disk then? My turbine and hub are all rotating, so I don't know how to handle this. Any suggestions? |
September 8, 2005, 16:43 |
Re: Rotating reference frame problems
I would suggest you to simply add a hole on your geometry. It's ture that CFX does not allow to have a zreo radius in the rotating frame.
Regards! Gab |
Installing OpenFOAM-1.5-dev on a cluster | ZKM | OpenFOAM Installation | 4 | December 25, 2010 15:59 |
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile | val46 | OpenFOAM Installation | 4 | August 27, 2010 03:43 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
how to treat the rotating zone in multiple reference frame (MRF) | Jiuan | FLUENT | 4 | May 24, 2010 21:58 |
Transforming results in rotating reference frame | Mark Render | Siemens | 0 | November 27, 2002 04:49 |
