The convergence strategy for a cavitation comp.?
Old   September 16, 2005, 07:08
Default The convergence strategy for a cavitation comp.?
Darcy
Dear all
In Tascflow what's the appreciated convergence strategy for a case with cavitation consideration? My case is a water jet impeller with diameter 147mm, 3 blade, and operating RPM 7800. The total pressure at the jet intake is estimated 4.5E+5 pa and mass flow at nozzle is about 50 kg/sec. A steady non-cavitating computation result is fed as inital guess. It seems that reducing fluid time step by 1/10 even 1/1000 can only improve a little and just add 5 step running then numerically overflow. What things else we can do to make this computation converge?
Thanks first.
Old   September 16, 2005, 07:15
Default Re: The convergence strategy for a cavitation comp
Darcy
Sorry to add something! cavitation model is CEV for attatched cavition sheet is most likely to happen and the cavitation bubble is the result of sudden pressure reduction to value under vaporization point. The far field temperature is 300K.
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Cavitation convergence problem Figd84 FLUENT 2 September 30, 2009 14:46
convergence problem with FLUENT cavitation model Belete Kiflie FLUENT 3 February 20, 2006 10:16
CAVITATION (convergence) ROOZBEH FLUENT 2 December 13, 2003 00:31
