September 22, 2005, 06:06 |
Turbulence model
Hi friends,
I am solving one tank flow problem, pipe connected to the tank(cuboidal shape - like room). I am solving for inlet Re in Laminar region (range 220 to 1350). The flow behavior is of SUDDEN EXPANSION FROM small inlet to large tank. I tried with Laminar model, for coarser as well as fine mesh, but it ends up with some error, mostly FINEMESS. Even if i get the results, those are not well converged and are unrealistic. When I use the 'k-e' model then it gives some results but i am not sure because i donot have any benchmarking/experimental results for this type of flow. So question is can we believe on use of k-e model? Any suggestions for analysing the results QUALITATIVELY? Hoping for good reply Tuks |
Display Modes | |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 10:02 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 14:57 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 11:26 |
Fan heater model: what turbulence source to use? | andy20 | CFX | 7 | March 3, 2008 17:42 |
SSG Reynolds Turbulence Model | Georges | CFX | 1 | February 28, 2007 17:15 |
