Home > Forums > CFX
SSH Instead of RSH
Old   September 27, 2005, 10:53
Default SSH Instead of RSH
Akano
My cluster was running rsh on Linux Redhat 7.3 up to CFX-5.7, Now I have to run Ansy CFX10, Which will be on Suse 9.3, how can I switch the rsh to ssh ?
Old   September 27, 2005, 11:10
Default Re: SSH Instead of RSH
Mikhail
It is not good idea, because ssh uses encryption which slow down cluster run. Furthermore rsh still present in SuSE9.3
Old   September 27, 2005, 11:51
Stevie Wonder
Hi Mikhail,
Could you expand on this please? Where did you see such information?
However, if security is not an issue, RSH is the right choice.
S.W.
Old   September 27, 2005, 12:00
Stevie Wonder
Use the following environemnt variable in all your nodes (bash syntax): export CFX5RSH=ssh
You'll should also want the ssh connections passwordless but this will require you extra steps. Otherwise it'll be annoying to type the password every time you launch a solver in each node.
Although not present by default in the 9.3 installation you can use the rsh rpm from the SuSE 8.2 version (if you still find it somewhere).
Good luck, S. W.
Old   September 27, 2005, 12:47
Mikhail
"OpenSSH encrypts all traffic (including passwords) to effectively eliminate eavesdropping, connection hijacking, and other network-level attacks. Additionally, OpenSSH provides a myriad of secure tunneling capabilities, as well as a variety of authentication methods." www.openssh.org
Mikhail
RSH client: ftp://ftp.suse.com/pub/suse/i386/9.3...7-556.i586.rpm RSH server: ftp://ftp.suse.com/pub/suse/i386/9.3...7-556.i586.rpm
RPM's should present in CD distribution
Thread Tools
Trackbacks are On
how to use -ssh w/ Fluent on Linux cluster Bill FLUENT 4 April 2, 2014 00:04
RSH on Windows for CFX parallel computation BalanceChen CFX 3 June 15, 2012 12:34
Rocks 5.4 Rsh Connection Refused for Fluent 6.3 bucnikf90 Hardware 2 March 29, 2012 16:24
running without rsh between nodes hattonps OpenFOAM 10 March 22, 2010 16:02
Using SSH instead of RSH for parallel Eric CD-adapco 4 October 11, 2002 08:13
