Home > Forums > CFX
How to define the Reynolds Number in CFX?
Like Tree1Likes
Old   November 6, 2013, 06:53
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
The streamlines are the velocity field. If you ignore that - then why bother doing CFD?
ghorrocks is online now   Reply With Quote
Old   April 27, 2014, 03:32
sepideh
sepidecent is on a distinguished road
Originally Posted by ghorrocks View Post
I do not understand your question. Are you having problems calculating the particle Re number? Are problems implementing you drag law?
Hi There,
Yeah I want to define Re Number as an expression in CFX-pre, and then drag coefficient. In that way I can define a new drag model than a common Schiller-Naumann correlation. Thank's a lot.
Regards,
Sep
sepidecent is offline   Reply With Quote
Old   April 27, 2014, 06:27
Have you done the tutorials? They show you have to implement CEL expressions.
Old   September 3, 2015, 22:09
Default How to check material properties valve in CFX.
  #24
N B Khan
bestniaz is on a distinguished road
How to check material properties valve in CFX. It just show the material like air, water.etc...no material propoerties here... Plz help me how to change the material properties...
I am new here and new in CFX.
Thanks in advance
Originally Posted by Loris88 View Post
Hi ghorrocks!
Since you have said me to read this post, I will write here my question.
I have read the questions and the relative answers but I did not find the solution for my problem.
I have a 2D problem. I created the mesh with ICEM and then I extruded it with the shrewdness of to put as depth, 1 cell like thikness.
After importing the mesh in CFX, I have put boundary condition of symmetry for to simulate the 2D problem.
I have these measures of the rectangular channel:
-Length: 3900 mm
-Heigth: 50 mm (Characteristic length L)
-Depth: 1 cell like thikness
-Re= 80000 (known input of the problem)
-Velocity along x axis= 24 m/s (u) at the inlet. The other velocities are 0 m/s. No swirl component.
-Dynamic viscosity: 1.8058e-05 kg/m*s (alpha)
-Density: 1.20438 kg/m^3 (beta)
-Kinematic viscosity: alpha/beta= 1.4993e-5 (ni)
Re= (u*L)/ni ~ 80000 [for precision 80034]
But Ansys has given me Re=9.2723E+04
How can I do for to solve this problem?
Thanks
bestniaz is offline   Reply With Quote
Old   September 4, 2015, 01:58
Lance
Lance is on a distinguished road
In CFX-pre in the tree to the left you have stuff like Simulation, Analysis Type, Solver, Coordinate Frames, and a thing called Materials. Right click, insert/material. Or from the menu in the top, click insert/material.
This is the easy part with CFD, and if you have problems with this you should at least do all the tutorials before doing anything else.
Lance is offline   Reply With Quote
Old   September 7, 2015, 00:59
N B Khan
Thanks dear... This forum is really great for the beginner... it help me alot....
Thread Tools
Trackbacks are On
Calculation of Reynolds Number In CFX ashtonJ CFX 12 July 17, 2015 06:32
Reynolds Number matching in Cavity flow Endee Main CFD Forum 6 April 20, 2010 04:47
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
Reynolds number in CFX tuks CFX 0 May 25, 2005 01:16
Low Reynolds number K-Omega modeling Athar Zaidi Main CFD Forum 0 October 31, 1999 14:59
