Exporting mesh to fluent
Old   August 29, 2005, 09:52
Default Exporting mesh to fluent
How does one export mesh from ICEM CFD to fluent. I tried doing it, created a .uns file but what to do with that file.
Thanx in advance
Old   August 29, 2005, 20:03
Default Re: Exporting mesh to fluent
zxaar
fluent comes with a utility to convert cfx mesh to fluent.
on console type
utility
and it will tell you what are the utilities available, among these there is one to convert cfx mesh to fluent, just follow the instructions.
Old   August 30, 2005, 08:59
Myron
The .uns file is still ICEM CFD format. You need to do Output > Select Solver (Fluent) > Then write the output. It will create the .msh file to read into Fluent.
Old   October 6, 2005, 03:12
fw_19
Im having dificulties with this as well. I can write the .msh file, but I get varying errors within FLUENT. How do you specify the interior/Fluid domains? I believe this may be the issue.
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
error when exporting mesh to fluent brusly FLUENT 0 November 23, 2006 01:29
Problems with exporting Gambit mesh to Fluent Alex Mozharov FLUENT 4 November 24, 2002 01:17
