Parallel license keys
Hi Everyone,
I was wondering if someone could explain the functionality provided by the following two license keys:
Many thanks Paul |
Re: Parallel license keys
I think the acfx_parallel key activates the parallel processing stuff, that is you need one of these per parallel run you wish to run simultaneously; and the acfx_par_proc key is the one which defines the amount of nodes you can use between all your parallel simulations. Regards, Glenn Horrocks |
Thanks Glenn,
That makes sense, and ties in with the error messages we've been getting. Regards Paul |
To run in parallel you need
1 solver license + whatever modules the physics demands 1 no_limit license 1 pararallel license n par_proc, where n is the number of partitions (minimum of 2) Regards, Robin |
