October 18, 2005, 02:24 |
Should I stop the run? Need urgent help.
Hi all....
I've one transient run on the SGI but it seems to freeze & not progressing anymore (top command shows 0.01% CPU usage). I checked the dir folder & out file. It stopped at writting the transient file 330.trn and I get a 330.trn.lck in the folder. It has been there for hours now. How could I restart the run without losing my previous results? I only left about 5% in this case. Thanks for help. |
October 18, 2005, 02:37 |
Re: Should I stop the run? It's a parallel solver.
Hi .... forget to mention....I'm running parallel solver at local nodes for this problem.
October 18, 2005, 18:26 |
Unless you have successfully saved a full result file you will not be able to restart. There is not enough information in a partial result file to do a restart. Glenn Horrocks |
October 20, 2005, 02:08 |
Thanks, Glenn.
I've tried cfx5stop or use solver manager to stop the run & save the results....However, the solver doesn't response anymore.... Anyone has sucessfully rescue such problem before? |
October 20, 2005, 18:50 |
Unfortunately you can only do a proper stop (that is writing a results file suitable for a restart) at the end of a timestep. If you cannot wait until the end of a timestep then there is no way of doing it, sorry. Glenn Horrocks |
Problem with cyclic bc when run on parallel | Tek | OpenFOAM | 2 | January 20, 2011 14:40 |
What's the best order to run this simulation in? | siw | CFX | 1 | November 4, 2009 19:42 |
serial run fine, but parallel run diverged | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | October 6, 2009 08:33 |
Restatring run | Tim | CFX | 2 | March 3, 2006 11:54 |
problems with LES run | Tim | CFX | 1 | February 27, 2006 07:28 |
