Patran Paver Mesh Mode
Old   September 1, 2005, 20:48
Default Patran Paver Mesh Mode
Soon
Hi there,
I'm trying to have a mesh as symmetry as I can in CFX and I know that Patran Paver Mesh Mode maybe could produce some improvement in Mesh.
But I couldn't find any function to activate this both in CFX-Mesh and ICEM.
Is there anyone have been doing this before? Thank you very much and every single advice is appreciated. Thanks.
Regards Soon
Old   September 2, 2005, 11:51
Default Re: Patran Paver Mesh Mode
Myron
ICEM CFD does have a surface paver (surface mesh only) - but you need the QUAD or AIQUAD. This will give you paved quads or tris or combination. Then you can extrude that surface mesh.
If you want periodic faces and one-to-one node matching on those faces - you'll need to describe your periodic conditions before running the mesh. This is in the Model Mesh Parameters area. Then the Tetra mesh will match the periodicity automatically.
Old   October 16, 2005, 04:53
mehul
Hi u can do it in cfx.as far as i know about cfx 5.6 u can go to tool>mesh mode an u ca nselect from three mesh modes.Default is AFI. oyhers are patran and isomesh.hope it helps u. regards
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 09:13
[Netgen] Netgen - Queries Batchmode & Verbose Mode shivaprasad123 OpenFOAM Meshing & Mesh Conversion 1 July 17, 2011 11:06
Importing Patran mesh into Gambit Trac FLUENT 1 September 29, 2005 10:32
Patran Mesh mode Maurício CFX 0 May 24, 2005 12:57
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
