Home > Forums > CFX
CENTRIFUGAL FAN
Old   October 17, 2005, 02:15
Default CENTRIFUGAL FAN
Txema
I am starting to simulate a CENTRIFUGAL FAN.
1.I have made the rotor wiht turbogrid 1.6
2.I have made the volute with CFX-Mesh
3.I have put massflow at inlet and pressure at outlet
4.The interface between rotor-volute is a Frozen rotor.
Pressure between experimental data and CFX data are quite diferent.
could anyone give me advise??
1.Is it o.k to mesh with CFX-Mesh for volute?
3.Wich type of interface I must put?
4.How I can model the gap between rotor(rotating) and inlet (static)
Old   November 24, 2005, 00:43
Default Re: CENTRIFUGAL FAN
sudarshan
Dear sir
This is sudarshan from india.
I am doing my MTECH in COMPUTER AIDED MECHANICAL DESIGN AND ANALYSIS.
I am doing a project titled " INVESTIGATION OF THE TWO DIMENSIONAL FLOW BEHAVIOUR DUE TO INTERACTION BETWEEN THE IMPELLER AND VANED DIFFUSER IN A CENTRIFUGAL FAN ".
The objectives of the projects are :
1) To locate secondary flow vortex.
2) Flow separation under different operating conditions and to establish design point operation of the pump.
The software tool used for the above is ANSYS.
I need your help for my project work.
Can you send me all the research papers involved in my project work.
I will be greatful to you if you send me research papers.
My email id is sudarshan2683@yahoo.co.in
Thanking you,
Yours faithfully SUDARSHAN
Old   November 28, 2005, 03:38
Txema
I do not understand what do you need exactly. Could you specify what do you need?
Regards, Txema
Old   December 25, 2005, 03:56
Mangesh
HI ALL,
I WORK ON DESIGN OF CENTRIFUGAL PUMP VOLUTE. 1) I WANT TO KNOW , TO CARRY OUT CFD ANAYSIS USING FROZEN ROTOR ,WHICH IS BEST STEADY STATE OR TRANSIENT..?
2)ANY MATERIAL RELATED TO VOLUTE DESIGN
Thanking you, Mangesh
Old   December 27, 2005, 04:03
Txema
Frozen rotor is a "photograph" of your problem at this time.
Use Frozen rotor to carry out your simulation at first and then use Transient simulation to get more accurate results.
With a transient simulation you can see the interaction between rotor and volute along time with different positions for the baldes.
Regards
Txema
Old   December 29, 2005, 08:09
mangesh
hi thanks
I AM GIVING TOTAL PRESSURE AT INLET AND MASS FLOW RATE AT OUTLET. BUT WHEN I CHANGE MASS FLOW RATE , TORQUE IS CHANGE ,
SO PLZ GUIDE ME FOR OUTLET BOUNDARY CONDITION.
Old   December 29, 2005, 11:44
Txema
These boundary conditions are o.k.
The torque, power, and raiting point Pressure-massflow change with massflow boundary condition.
Have you ever saw a centrifugal fan plot??
Because this is how fans work.
Txema
Thread Tools
Trackbacks are On
Modeling of centrifugal fan in CFD Simon Williams Main CFD Forum 3 February 20, 2009 16:00
Multiple reference frame in centrifugal fan Peter Main CFD Forum 0 April 8, 2008 05:37
How to model flow of centrifugal fan? Peter Main CFD Forum 0 April 2, 2008 06:07
boundary condition for centrifugal fan vishal FLUENT 0 November 6, 2007 07:29
centrifugal pump and centrifugal fan Mangesh Main CFD Forum 3 January 3, 2006 12:21
