October 13, 2005, 08:59 |
Any one solve this parallel problem?
On install of a new parallel setup on Windows Xp, I get a Terminal readThe handle is invalid error. Any advice short of reformating the computers?
Thanks! |
October 13, 2005, 09:34 |
Re: Any one solve this parallel problem?
Assuming that you have rsh setup correctly (see the documentation for how to test this), then Service Pack 2 for Windows XP introduced a rsh problem that would produce this message. The easiest solution is to install the latest release (CFX-10). Mike
October 15, 2005, 03:36 |
how about the speed of parallel solution in Winxp?
October 16, 2005, 19:06 |
CFX runs well in parallel under WinXP. The MPICH for Windows option is as good as CFX in parallel under Linux in my experience. Glenn Horrocks |
October 18, 2005, 10:40 |
Here is the follow up fix for this error. Anys support guys presented this solution:
Installation Root = C:\Progra~1\Ansys~1\CFX\CFX-%v should replace: Installation Root = C:\Program Files\Ansys Inc\CFX\CFX-%v on anybody that is a slave. No spaces in the path for the slave... amazing. Thanks, Erich |
Display Modes | |
how to solve a problem involving both laminar and turbulent flow | seefd | FLUENT | 1 | June 3, 2011 03:20 |
problem using property udfs in parallel mode | EllenW | FLUENT | 0 | June 23, 2009 17:18 |
problem with parallel system | tahere | FLUENT | 2 | December 27, 2008 18:44 |
parallel UDF problem | kerem | FLUENT | 2 | June 20, 2006 06:56 |
parallel mode - small problem? | co2 | FLUENT | 2 | June 1, 2004 23:47 |
