amd athlon64 cpu and cfx 5.7.1 solver
Old   October 18, 2005, 16:46
Default amd athlon64 cpu and cfx 5.7.1 solver
cmete
I want to know that cfx 5.7.1 solver is how much convenient and efficient with amd athlon64 3000+,1800MHz,640kb cache box,socket 939 cpu? In addition, can I use cfx 5.7.1 with Windowsxp 64bit edition? best regards...
Old   October 19, 2005, 02:52
Default Re: amd athlon64 cpu and cfx 5.7.1 solver
Young Seok, Kang
I'm using the same CPU with yours. So far, I have not faced any problems with this CPU on windows xp. It takes neary one day to solve a problem with approximately one million grids which consist of both structured and unstructured grids.
I think the convenience problem depends on how much physical memory you're using and what is your os.
You can use cfx 5.7.1 with windows xp 64 bit edtion. But I strongly recommend if you can handle linux, use 64 bit linux such as redhat enterprise. Is windows xp released? I heard windows xp is still under beta testing.
best regards
Old   October 19, 2005, 05:47
cmete
I did not install cfx yet, so that I have no any experience about it but I wondered it for any efficiency diffrences between intel p4 and athlon64 cpu.
I am using 1GB physical memory that was not enough for other cfd software sometimes.
I think the 64 bit computing should be so fast than the 32 bit computing. if can I use 32 bit windows and 64 bit linux together on the same computer , I would try 64 bit linux in cfd applications.
And thanks for your response.
best regards.
Old   October 20, 2005, 22:16
Neale
64 bit vs. 32 bit has no performance impact. It only gives you larger memory addressability. 5.7.1 is only 32 bit software so you will still be limited to ~ 2.7 GB on 64 bit linux and 1.7 GB on Windows.
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
CFX Solver : Sudden crash Hervé CFX 2 June 16, 2008 06:40
Cpu Slowening & CFX Flavio CFX 1 November 26, 2006 16:23
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
CFX 5.7 on P4 2.4 and AMD Athlon 64 3000+ Dmitry Korshun CFX 4 November 28, 2004 10:45
