October 17, 2005, 17:49 |
ICEM - irregular mesh at edge ?
Hi, I am new to ICEM-CFD. I imported an iges (or stl) file to icem-cfd. When I refined the boundary using prism layers, I always get bad edges (not smooth as in the original CAD file). i.e. the algorithm did not mesh according to the CAD edge (especially at orthogonal planes) Does anyone know what went wrong ? Thank you in advance. (version: ICEM-CFD 5.1)
-Ethan |
October 17, 2005, 18:55 |
Re: ICEM - irregular mesh at edge ?
Are there lines on all hard edges of the geometry? ICEM need lines at hard edges and points at hard points. Regards, Glenn |
October 18, 2005, 09:09 |
As Glenn mentioned you want curves and points that define hard features in the geometry. The best way to get these is via Geometry > Repair Geometry > Build Diagnostic Topology. You'll need to designate an appropriate tolerance value (typically 1/10 your smallest desired mesh element size) and a filter angle. The filter angle is used to remove points and curves that don't define hard features in the geometry.
October 18, 2005, 14:31 |
Thank you to both of you. I will try it.
Display Modes | |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
ICEM - mesh near wing trailing edge | Joao Lourenco | CFX | 5 | August 30, 2007 17:20 |
ICEM clustering of mesh points and multiple edges | webhaw | CFX | 4 | July 25, 2007 16:29 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
