amd athlon64 cpu and cfx 5.7.1 solver
I want to know that cfx 5.7.1 solver is how much convenient and efficient with amd athlon64 3000+,1800MHz,640kb cache box,socket 939 cpu? In addition, can I use cfx 5.7.1 with Windowsxp 64bit edition? best regards...
Re: amd athlon64 cpu and cfx 5.7.1 solver
I'm using the same CPU with yours. So far, I have not faced any problems with this CPU on windows xp. It takes neary one day to solve a problem with approximately one million grids which consist of both structured and unstructured grids.
I think the convenience problem depends on how much physical memory you're using and what is your os. You can use cfx 5.7.1 with windows xp 64 bit edtion. But I strongly recommend if you can handle linux, use 64 bit linux such as redhat enterprise. Is windows xp released? I heard windows xp is still under beta testing. best regards |
I did not install cfx yet, so that I have no any experience about it but I wondered it for any efficiency diffrences between intel p4 and athlon64 cpu.
I am using 1GB physical memory that was not enough for other cfd software sometimes. I think the 64 bit computing should be so fast than the 32 bit computing. if can I use 32 bit windows and 64 bit linux together on the same computer , I would try 64 bit linux in cfd applications. And thanks for your response. best regards. |
64 bit vs. 32 bit has no performance impact. It only gives you larger memory addressability. 5.7.1 is only 32 bit software so you will still be limited to ~ 2.7 GB on 64 bit linux and 1.7 GB on Windows.
