CFX pre command editor error
I am using CFX10 and trying to create a FORTRAN subroutine in the command editor I wrote:
! system ("cfx5mkext myfortran.F") == 0 or die; Myfortran.F is my fortran subroutine I got the following massage: ERROR CCL parser failed with message: Perl Syntax errors detected: Died at (eval 39) line 1. what this massage mean and how can I sort this problem out Regards |
Re: CFX pre command editor error *NM*
It's not the most helpful error message! If you look in the DOS windows assosiated with CFX (it will be minimised), I expect you'll see the error:
The compiler command "df" could not be found. ..... So you would either need to install a Fortran compiler or make sure the command to launch it (df) is on your PATH environment variable. Mike |
