More Rotating reference frame problems
Old   October 22, 2005, 16:24
Default More Rotating reference frame problems
DaveG
Thanks for the help last time, Gab.
Hitting my head on a wall here, for some reason CFX doesn't like my geometry. Here's the error:
ERROR #999100159 has occurred in subroutine SET_ZONE_PITCH. Message:
The determined pitch angles in the domain FLUID differ more than the allowed tolerance: First pitch angle: ******** degrees Second pitch angle: 360.000 degrees Allowed tolerance: 360.000 degrees
I've had a few successful rotating ref runs, but this new geometry is causing problems. I'm modeling the entire rotating frame, no periodicity. The mesh is high quality, and I have a sizeable hole in the centre. Basically it's just a rectangular block on a rod (ie, the hole) rotating in a large block of symmetry plane bound water.
Has anyone encountered this before? I've tried specifying the ratio, same error. I've tried specifying the pitch angle, I get a "possible zero radius" error then. I've enlarged the hole to no avail. My rotation axis is in the exact centre of an axisymmetric cylinder.
Any insights would be greatly appreciated!
-Dave
Old   October 24, 2005, 10:18
Default Re: More Rotating reference frame problems
Gab
Hi, Dave
Did you set the Frame Change option to 'automatic'? If so, you can change to 'none'. I assume that no pitch occurs in your problem.
Regards!
Gab
Old   October 26, 2005, 16:47
DaveG
It works! Thanks again, Gab.
I guess I misunderstood the Frame Change option.
Installing OpenFOAM-1.5-dev on a cluster ZKM OpenFOAM Installation 4 December 25, 2010 15:59
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 03:43
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
how to treat the rotating zone in multiple reference frame (MRF) Jiuan FLUENT 4 May 24, 2010 21:58
Transforming results in rotating reference frame Mark Render Siemens 0 November 27, 2002 04:49
