CFX post for turbomachinery
Old   November 17, 2005, 23:22
Default CFX post for turbomachinery
John
Hello everyone, I simulate flow inside pump. In simulation one blade is used. When I create turbo surface it shows the flow with the blade in the middle. When I use two blades, I see flow field parameters, pressure contours or velocity, between the two blades (pressure side of blade 1 and suction side of blade 2). Also, there are extra contours drawn on the suction side of blade 1 and pressure side of blade 2.
How I can create a turbo-surface to show flow between a two blades without the extra contours in the other side of the blades.
How to get reynolds stress values in POST CFX syler3321 CFX 6 January 1, 2017 07:54
CFX post legend modification mactech001 CFX 3 December 25, 2011 22:12
CFX post - graph kmgraju CFX 0 July 22, 2010 11:59
Chart Generation in CFX Post Vadim Baines-Jones CFX 2 August 28, 2007 09:14
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 16:42
