ANSYS license message
I am using CFX 5.7.1 and the license is due to expire in 30days. Hence everytime I open any of CFX products, an ANSYS license message pops up, stating that the license is due to expire in ...days. The application will only start once I hit the OK button. Now I need to use the solver in batch mode and this wont start until I hit the OK button. The first run will go through as I am present, but what about the others when I am not. Any methods to avoid this message apart from getting the new license? Regards, Santhosh |
Re: ANSYS license message
Yeah, these messages occur only in M$-Windows. That might exist (at least it should exist) some environment variable that controls such annoying messages but I'm also interested in that.
S.W. |
if you have a little experience in programming you can build a small program that periodically looks for Ansys license popup windows and sends them a closure message (you just have to set a timer and to check the names of open windows). Since I don't have Administrator privileges on my computer, I couldn't find an easier way to get rid of those messages. I hope you'll find it useful... ciao |
Thanks,
This problem was solved with the help of Tech Support, just need to add an environment variable and that would get you through to 7 days before the license expires. Santhosh |
And would you share this environment variable with us?
S.W. |
Its,
ANS_FLEXLM_EXPWARN_DAYS = 'days' Santhosh |
| All times are GMT -4. The time now is 16:51. |
