Home > Forums > CFX
Output force as a function of time
Old   November 21, 2005, 23:54
Default Output force as a function of time
Andrew
I've been trying to export force on a body as a function of time from CFX-10 with little success. I can get the data I want as a txt file if I export from a chart (using expression eg. forze_z@body wall vs. time), but...I want to fully automate this to fit in with the rest of my automisation scheme i.e. not need to open post.
Help Appreciated
Old   November 23, 2005, 01:31
Default Re: Output force as a function of time
test
You can do this using a simple perl script which has to loop over different transient result files. contact your local support office and you should get one easily.
Regards, test
Old   November 23, 2005, 19:12
James Date
I posted this a while back.
To take the forces from each of the transient output files use something like the script written below.
You need a session file and a DOS batch file.
# Session file started: 2004/10/21 10:38:42 # CFX-5.7 build 2004.04.01-23.00
! open (DATAFILE,">>Datafile.txt") or die "File Error\n";
! $filePath = getValue("DATA READER","Current Results File");
! $torque_x = torque("Rotor","X");
! $torque_y = torque("Rotor","Y");
! $torque_z = torque("Rotor","Z");
! $force_x = force("Rotor","X");
! $force_y = force("Rotor","Y");
! $force_z = force("Rotor","Z");
! $Cp_chord_wise = $torque_z/$force_y;
! $Cp_span_wise = $torque_x/$force_y;
! format DATAFILE= ! @>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>> @>>>>>>>>>>>>> @>> @>>>>>>>>>>>>> @>> @>>>>>>>>>>>>> @>> @>>>>>>>>>>>>> @>> @>>>>>>>>>>>>> @>> @>>>>>>>>>>>>> @>> @>>>>>>>>>>>>> @>> @>>>>>>>>>>>>> ! "Full Path and Run Number", "Force-X (N)", "", "Force-Y (N)", "", "Force-Z (N)", "", "Torque-X (N*M)", "", "Torque-Y (N*M)", "", "Torque-Z (N*M)", "", "Cp-Chord (M)", "", "Cp-Span (M)" ! @>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>> @.############ @>> @.############ @>> @.############ @>> @.############ @>> @.############ @>> @.############ @>> @.############ @>> @.############ ! $filePath, $force_x, "", $force_y, "", $force_z, "", $torque_x, "", $torque_y, "", $torque_z, "", $Cp_chord_wise, "", $Cp_span_wise !.
! write DATAFILE;
! close DATAFILE;
>quit
# Session file stopped: 2004/10/21 10:40:42
DOS Batch File
@ECHO Off
C:\CFX\CFX-5.7\bin\cfx5post -batch T:\ANSYS_CFX\Post_session.cse T:\ANSYS_CFX\1\1_001.res
C:\CFX\CFX-5.7\bin\cfx5post -batch T:\ANSYS_CFX\Post_session.cse T:\ANSYS_CFX\2\2_001.res
You could gave done some kind of perl loop, but i figured this was quicker to do.
Regards James
Old   December 6, 2005, 16:16
HR
If you can do it interactively, then you can do in the batch mode as well. All you need to do is make a session file out of your interactive session: 1. start Post 2. start recording a session (Session > New Session, then Session > Start Recording) 3. load file, make your chart, export data, etc. 4. quit You can now tweak the recorded session if needed and play it back in batch mode.
Old   August 19, 2013, 09:23
A_Prakash is on a distinguished road
I have been fiddling with things in CFD-post. I know just enough about session file to automate the routine tasks I perform.
However, I am now thinking of adding some fool-proofing options via GUI to my .cse file so that a colleague can interact with it through a message box.
Here is my question: How can I use a Perl command to display a simple message box as part of my .cse file execution?
P.S Don't wish to be ignorant.. but, I have been struggling to get to a good staring point on using GUI thru perl. I am completely new to scripting... but, with some help-in-context baby steps.. I know I will be up and running fast... Thanks.
A_Prakash is offline   Reply With Quote
Thread Tools
Trackbacks are On
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Force Report help~ or maybe Custom Field Function sailor FLUENT 0 April 13, 2011 03:45
Full force and moment coefficient output Newfoamy OpenFOAM 6 March 17, 2010 04:19
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
Residence time distribution function Roustam Phoenics 3 February 26, 2002 09:47
