Cavity presntation on pump blade
Old   November 23, 2005, 15:50
Default Cavity presntation on pump blade
ali
Hello everyone,
I'm modelling cavitation inside pump. I'd like to present cavity on blade surface as a 3D cavity using CFX-post. Is that possible and how I can do it.
Ali
Old   November 23, 2005, 16:14
Default Re: Cavity presntation on pump blade
In CFX-Post, do an iso-surface of volume fraction.
Old   November 24, 2005, 12:24
ali
Thank you Glenn, this is very helpful
Ali
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 02:33
[GAMBIT] influence between angle in impeller blade and centrifugal pump performance barak182 ANSYS Meshing & Geometry 2 August 18, 2010 03:07
Regenerative pump modelled in FLOEFD pro YYY FloEFD, FloWorks & FloTHERM 2 October 5, 2009 05:04
meshing blade centrifugal pump mino CFX 5 December 2, 2006 00:54
Calculate pressure on pump blade during cavitation CFX_USER CFX 0 April 12, 2006 12:54
