Home > Forums > CFX
Free Surface Flow: Length of Interface?
Old   November 29, 2005, 16:45
Default Free Surface Flow: Length of Interface?
Chebeba
I am playing around with analyzing performance of a sailboat hull using the homogenous free surface model. I've gotten grips on most things, but one thing bothers me: The Water/Air interface is more than a meter wide, even where there is no turbulence at all. (I am using "Interface Compression = 2").
Anyone here with experience on how this influences the accuracy of my results?
/C
Old   November 30, 2005, 03:40
Default Re: Free Surface Flow: Length of Interface?
Charles
You are never going to do it with a grid like that. You need very fine resolution normal to the water surface, something like 10 mm or so. It won't work with a tetrahedral grid. You might make it work with prism layers, but the answer is to use a hexahedral grid.
Charles
Old   November 30, 2005, 06:13
Chebeba
Well I could feel that comment coming, that's why I included the mesh in the picture ;-)
The next question then is how to create such a mesh? I am using an inflated boundary around the hull regions to create the boundary mesh needed by the SST turbulence model. This boundary is very thin (resolution ~1mm). So I can't apply the same inflation to the water surface region. But it seems not to be possible to specify two different sets of Inflation parameters, only several surfacegroups using one set of parameters.
/C
Old   November 30, 2005, 09:57
Rui
Perhaps you could use mesh adaption as in Tutorial 7 (Free Surface Flow Over a Bump)
By the way, what actually is "Interface Compression"? I think it wasn't available in CFX-5.7.1. Does it have something to do with the compressive advection scheme?
Regards,
Rui
Old   November 30, 2005, 16:56
Chebeba
No idea, but the manual says to set it = 2 if the fluid interface is too spread out It did improve...
Old   December 1, 2005, 00:30
Neale
To improve your mesh you could put a subdomain boundary "around" the region you expect the free surface to be located. Then inflate off of that in both directions. Inflation does not have to be off of no-slip wall boundary conditions only.
This is only really useful though if the free surface ultimately conforms to an expected shape.
Neale.
Thread Tools
Trackbacks are On
Free surface flow settubg boundary conditions and plotting velocity profiles prashanthreddyh FLUENT 2 October 21, 2015 09:58
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
How to determine delta t for free surface flow phsieh2005 Main CFD Forum 0 September 14, 2005 11:52
incompressible free surface flow past cylinder vineet FLUENT 2 April 1, 2002 05:56
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
