Home > Forums > CFX
ICEM Blocking stability?
Old   December 1, 2005, 12:29
Default ICEM Blocking stability?
Is it only the machine I am working on, or is the "Split Block by prescribed point" functionality in ICEM 10 extremely buggy? It seems the first op in a session is alway OK, but then you have to restart ICEM for the next one...
Old   December 1, 2005, 17:26
Default Re: ICEM Blocking stability?
Yes, I agree - ICEM is buggy. The current release is much better than previous ones, but still it is quite buggy. However before people get hot under the collar about that, bear in mind that I am yet to find a meshing software which is not buggy. IMHO ICEM is one of the better and more reliable ones.
The best way to help is to report the bug to CFX and hopefully it can get fixed.
Regards, Glenn Horrocks
Old   December 1, 2005, 18:04
I have used "Split Block by prescribed point" in ICEM CFD 10 quit a lot without too much trouble. Does your problem happens all the time when you use that function?
Old   December 2, 2005, 01:02
I have problems like this when my model gets complicated and the ORFN blocks get "tangled". If you delete the ORFN blocks (checking the box for permanent deletion), ICEM will rebuild the halo of ORFN blocks around your block structure.
Turn all parts off except ORFN. Select Delete Blocks. Check "permanent deletion" Select all the ORFN blocks on the screen and Apply.
I suggest saving everything to a new project before doing anything like this.
Thread Tools
Trackbacks are On
[ICEM] Using Blocking with ICEM (infinity lines appear) Touré ANSYS Meshing & Geometry 6 August 5, 2012 17:07
No Blocking tab in Ansys ICEM CFD11.0 NewGuy CFX 1 November 22, 2010 16:38
Ansys ICEM 12.0 Searching for tutorial information on complex 3d blocking Raoul ANSYS 1 October 18, 2010 06:08
ICEM blocking Chris Wetton CFX 6 March 9, 2008 06:18
ICEM Blocking 2D and Fluent error Dr. Flow Squad FLUENT 3 March 5, 2007 03:27
